Backhoe Mahindra Backhoe 3375
/ Mahindra Backhoe 3375 #1
Covington,La.
Mahindra 2810
Can anyone tell me if Iam getting a good price for this 3375 Mahindra Backhoe. They quoted me $7,468.00 for a complete unit installed on my tractor with sub frame, pto pump for added power, 12" bucket, including sales tax. Tractor is a 2810
/ Mahindra Backhoe 3375 #2
gary,
I paid 7,000 for 3375 on my 2810hst without pto pump and 16" bucket, here in new england prices seem to be higher. recently purchased 12" bucket to dig some post holes, post hole diggers don't work on my property too many rocks, don't believe it is a good first chioce bucket, can't put enough in it, I would go with the 16". I never found a need for a pto pump, fast enough for me using tractor pump but i do not use it everyday. I may be wrong but the pto pump will not give you more power just more speed, the pressure relief will kick in. good luck glenn.
/ Mahindra Backhoe 3375 #3
My setup is the same. A 3375 with a 16 inch bucket on a 2810HST. I also paid $7,000.00 last year. So if your getting one with a PTO pump, I would same that's a good deal.
The bigger hoes seem to work better with the PTO pump , but pump doesn't seem to be needed on the 3375 hoe.
Although if I had a PTO pump I May not say that.
I like the sub frame setup on the 10 series tractors. It is up high and doesn't lower your ground clearance.
Dave in NH
/ Mahindra Backhoe 3375 #4
gary i have the 2810 with a 3265 hoe and i'm taking to my dealer about putting the pto pump on mine.the price seams to be fair that they quoted you.good luck
Thanks for all of the good feed back. I will more than likely by it shortly after the first of the year. Will let you all know how it works.
Have good holiday season.
Gary
Need some more help on the 3375 backhoe attachment. Before I purchase this unit I would like to hear comments from anyone that actually has a Mahindra 2810 with this or any other type of hoe on the back. I would even drive 50 - 100 miles if I could look at the unit on this type of tractor. Just want to be sure before I spend this kind of money.
Thanks in advance for the info.
Gary
/ Mahindra Backhoe 3375 #7
Hi Gary
I have a 3710 backhoe with a 12 bucket on a 2615 mahindra here and it works very smooth and fast.
Its a clean looking piece, no hoses or sharp corners to get in the way at all.
If I was closer you could try it out
Ernie
Ernies imports
/ Mahindra Backhoe 3375 #8
I have a 2810 HST with the 3375 hoe and like it very much.
I looked at a lot of tractors when I went with Mahindra. I really like the sub frame setup they use. The Hoe comes off and goes on very easy and you don't loose any ground clearance.
I am a little to far away for you to look at , but I will put some pictures on.
Again thanks to all for the info. The picture of yours dbelisle makes me really want one. I will let you all know when I get mine and how it works.
Thanks,
Gary
2020 CATERPILLAR 299D3 SKID STEER (A64279)
2020 CATERPILLAR...
2016 Ford Escape SUV (A61574)
2016 Ford Escape...
CASE 105C (A62177)
CASE 105C (A62177)
2024 Teagle Tomahawk 8500 (A63688)
2024 Teagle...
2018 Cat D6T LGP VPAT Dozer (A62679)
2018 Cat D6T LGP...
2021 John Deere HD35R Draper Head (A63111)
2021 John Deere...
