Mahindra back lift
   / Mahindra back lift #1
gjbjstrahan
Hull Texas
Mahindra
When I turn on my tractor lift goes up but will not come down.
   / Mahindra back lift #2
On my Mahindra there is a control knob under the middle of the seat. It controls the speed the 3 pt. goes down. If it is shut or closed (clockwise) the 3 pt. won't go down. Check yours to see if it is closed.
thank you will try in the morning.
   / Mahindra back lift #4
I've got a 3505DI Mahindra and my lift stuck last week, would not go up or down. I'm real interested to see what the outcome of your issue is. I feel fairly sure my problem is because I've not changed my hydraulic fluid and filter and now have almost 500 hours on the tractor. Keep us updated on what happens with yours.
   / Mahindra back lift #5
That happened to me a month ago, with a 2*2*2 boulder on the forks.... Not a comfortable feeling. Eventually got it down, but don't know how exactly... Did play with that control knob, but it was not reactive within first hour... Which surprised me. I need to learn why this happens too. It happens on all brand of tractors, as I've seen in the various threads.
   / Mahindra back lift #6
Turn the knob counter clockwise, and if no results, remove and inspect , clean and look for rust, etc.
The pressure that the knob exerts determines how much fluid escapes the cyl when the lever is set to down. If you lock the knob down, the 3pt arms will stay up, and is used for transport or to lock in any position.
It didn't work. I haven't changed the filter because i didn't have near enough hours or right tools. Guess I will track tools down and try that next. My trailer is to small to take it in might end up having to borrow a trailor. Thanks
20711 (A50323)
20711 (A50323)
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2003 Chevrolet 3500 (A50120)
2003 Chevrolet...
2011 Ford Explorer SUV (A53424)
2011 Ford Explorer...
(INOP) JOHN DEERE TS GATOR (A51247)
(INOP) JOHN DEERE...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
