Mahindra 75B / Bradco 509 Backhoe Spool Valve Seal Leaking & Replacement (how to)
   / Mahindra 75B / Bradco 509 Backhoe Spool Valve Seal Leaking & Replacement (how to)
Re: Mahindra 75B / Bradco 509 Backhoe Spool Valve Seal Leaking & Replacement (how to
Yep, something about hindsight. I知 kicking myself in the butt. Should have had a hydraulic shop size them for me. Good news is that getting the control body out isn稚 that difficult. I replaced the o rings in my dozer a couple of years ago and it required hoists boards etc. just to get that heavy thing out.
haha, ya live and ya learn. I can only imagine the weight of a giant cast piece in a dozer. That's probably definitely the limit factory once you get in to heavy equipment. Hopefully you get your unit sealed back up shortly; there's not much to them at all.
Here y'all go. The exact part number I used.
Item Number: 2-210 N70
Description: 70 DURO BUNA N O-RING
Item Number: 2-116 N70
You can probably good that and confirm the specs with what i measured originally just to make sure. But maybe that help someone.
   / Mahindra 75B / Bradco 509 Backhoe Spool Valve Seal Leaking & Replacement (how to) #13
Thank you for this post, it has helped me out a ton!
43018 (A51691)
43018 (A51691)
Diesel Forklift (A51691)
Diesel Forklift...
2018 FORD EXPEDITION (A51406)
2018 FORD...
Toro Workman 200 Sprayer Cart (A50322)
Toro Workman 200...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
