Mahindra 75B backhoe hookup
   / Mahindra 75B backhoe hookup #1
akax50
Lothian, Md.
mahindra 2555 hst cab
Got a 75B backhoe on Mahindra 2555. The remote hookup has two female connections with two male connections on hoses coming from bh. One hose from bh has a filter and the other is a check valve. The lever to activate the remote has a retract position and an extend position. Does this mean that in retract position that oil flows in one direction and in extend the oil flows in the opposite direction through the remote? The bh came from dealer with hose with filter attached to right side remote connection and the lever set to extend to operate the bh. Would it be safe to assume that switching the hoses and putting the lever in retract position would work as well?
   / Mahindra 75B backhoe hookup #2
If you switch the hoses from the way the dealer had them then the hoe won't operate correctly. Why would you switch them anyways? Or I could be misunderstanding you
   / Mahindra 75B backhoe hookup #3
I re read your post, I think I understand now. I assume it would work like you're talking about doing. But why would you want to? Just curious.
Have several people that will be operating the tractor and I was just wondering if it was hooked up differently if that would be an issue?
   / Mahindra 75B backhoe hookup #5
Ahhh I see. You could get some colored electrical tape and color code the hoses to the proper quick connect. Takes the guess work out of hooking up hoses
   / Mahindra 75B backhoe hookup #6
Get some plastic wire ties in a couple colors. They'll hold up better than tape.
   / Mahindra 75B backhoe hookup #7
Didn't even think about colored wire ties. That's much better than tape that would turn to crap when the hydraulic fluid got on it from disconnecting couplers
   / Mahindra 75B backhoe hookup #8
huh?.........
   / Mahindra 75B backhoe hookup #9
Tape would deteriorate pretty quick and come off when the hydraulic fluid gets on it vs ties that won't deteriorate.
   / Mahindra 75B backhoe hookup #10
my bad.
I read it as "Don't even think about colored wire ties."
My old eyes ain't as good as they once was.
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
NEW Wolverine Skid Steer Bucket Forks (A53002)
NEW Wolverine Skid...
2019 Chevrolet Tahoe SUV (A50324)
2019 Chevrolet...
2022 JOHN DEERE 410E II (A52472)
2022 JOHN DEERE...
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
1996 Fiat Allis FG 65C Motorgrader (A51573)
1996 Fiat Allis FG...
