Buying Advice Mahindra 6525?
/ Mahindra 6525? #1
japody
Platinum Member
Richmond & Boydton VA
Ford 4000 & 5000, New Holland TN65, Mahindrda 2516
Anyone have any thoughts or experience with the Mahindra 6525 or any other model near this size? I'm thinking about one for my next tractor - including FEL, SSQA and filled tires. Thanks for any input!
/ Mahindra 6525? #2
Japody,
I have a 2007 6520 4WD with Bradco 511 backhoe and love it. Only things that have shut me down where a steering cylinder line leak and a crack in the hydraulic pump's pulley. That's all in a little over 800 hours. The 6520 was repalced by the 7060. Make sure it has two remotes.
hugs, Brandi
/ Mahindra 6525?
Thanks for the reply Brandi. I've read where some people had problems with the hydraulic lines placed under the tractor and hanging up on stuff. Have you had any similar problems?
/ Mahindra 6525? #4
No problems with snagged lines. But I had a some brush pull the neutral saftey switch wires off when I was brushogging. No problem until I tried to start the tractor after lunch.
hugs, Brandi
/ Mahindra 6525?
If I do decide on this tractor, I'll have to see if there is anything hanging down and figure out how to secure it.
Thanks again.
