Oil & Fuel Mahindra 6500 4WD
   / Mahindra 6500 4WD #1
bl3167
Mahindra 6500
I am trying to find where I put Power steering fluid in the tractor. It has been leaking at the rack cylinder by the left front wheel. Been looking but no luck.
   / Mahindra 6500 4WD #2
I don’t have that model but most tractors don’t have “power steering fluid” as they use the hydraulic system to “power” the steering.
On that machine I’m assuming it holds 10-15 gallons of hydraulic fluid. With that said you would need one big leak to notice a drop in fluid to the point more would need to be added.
Again, these remarks are generalized as I don’t have that machine.
   / Mahindra 6500 4WD #3
Trace back the hyd. line from the left front wheel (hyd piston) to the side of the engine...you should find a reservoir that has a twist off top...that's where the fluid goes...PS: it takes something besides regular hyd. fluid... My 6000 (pretty much same tractor) is this way...it only holds a quart or so..there should be a dipstick at the bottom of the cap...good luck...PSS: call your Mahindra dealer....PSSS: You will note the 6500 has two hyd pumps in tandem...I believe the rear pump is the power steering....BobG in Va
   / Mahindra 6500 4WD #4
Looking from front of tractor its standing up in upper left corner of engine compartnent. it is a large cap and unscrews. You will have to remove the overfow connection on side
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
LANESHARK LS3 LOT NUMBER 161 (A53084)
LANESHARK LS3 LOT...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
1995 GMC CHIPPER/BUCKET TRUCK (A52576)
1995 GMC...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
