Oil & Fuel mahindra 6500 4wd hydralic question
   / mahindra 6500 4wd hydralic question #1
model12
Mahindra 6500 4wd
Hey yall, I'm new here. I've lost my operators manual and I need help. I just removed my hyd filter and replaced it. I need to drain the remaining fluid and replace. Where is the hyd drain plug, and where do I re-fill? There is a plug behind the seat that has a dip stick attached to it...is that the fill hole? Its rather small. Thanks....:)
Kim
   / mahindra 6500 4wd hydralic question #2
Do you have a loader installed? If so you will see where the return from the loader valve goes in the back of the hydraulic reservoir, that is where the hydraulic drain is. The easiest way to drain it is to disconnect that hose from the loader valve, and let it drain into a bucket. The fill hole is on the Rt rear corner kind of under the seat, if the seat is back all the way. There is a dip stick on the fill plug.
I hope this helps, and if not let me know and I will try to expain it better.
Thanks for the reply. I do not have a loader. I assumed that the fill plug was the one with the dip-stick in it behind the seat. I was confused because there is another plug about foot under the one just behind the seat...
   / mahindra 6500 4wd hydralic question #4
Well the drain plug is just just about 10 " below the fill plug facing the rear. If you put a short length of hydraulic hose on the drain plug and a plug on the end of that, your draining operation will be much cleaner the next time.
The dipstick below is for your transmission fluid.
Land Honor Skid Steer Bale Spears (A50515)
Land Honor Skid...
2023 Trailerman Gooseneck (A50514)
2023 Trailerman...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2011 Chevrolet Equinox SUV (A50324)
2011 Chevrolet...
2013 Ford F-150 Pickup Truck (A50323)
2013 Ford F-150...
