3-Point Hitch Mahindra 6500 2nd weak lift
   / Mahindra 6500 2nd weak lift #11
it is also possible that your control valve is stopped up or not working right... you can take it out to be sure its opening and closing like it should.. brake cleaner never hurts while you have it out.
Agreed. Just looked at the service manuel. If the draft control is OK its more that likely the issue is in the valve. There are lots of components to it. :confused3:
   / Mahindra 6500 2nd weak lift #12
If it was filter/strainer plugged loader and remotes would not work. It's gotta be in the hitch itself. Either draft stuck or in Valve. The hitch cover assembly will have to come off for repairs.
All hydraulic functions slowed, especially when cold. Removed and cleaned pre-filter screen (thank you for the picture!). It was not plugged. No improvement in lift rate but the three point hitch function started working again. Luckily enough just draining the fluid and refilling "fixed" the 3 point lift.
A new screw on filter (later) restored overall lift speed and cool weather operation. Used the cheapest yellow pail Tractor Supply hydraulic fluid. I wish I had used something else as the net indicates it has poor cold weather performance.
Thanks to everyone
5'x8' Rubber Mats (A55272)
5'x8' Rubber Mats...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
1997 Moxy MT30 Haul Truck (A55272)
1997 Moxy MT30...
Concrete Gearbox (A57454)
Concrete Gearbox...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2018 Ford F-150...
2015 CAT 950M Wheel Loader (A55272)
2015 CAT 950M...
