Mahindra 5570 won't turn over
   / Mahindra 5570 won't turn over #1
Tannyleblanc
Dequincy, LA
2015 Mahindra 5570
Recently purchased a 5570, spent about 10 minutes on it after I got it home from dealership and now tractor won't start. All lights come on as before when I turn key on but will not turn over (crank). All gears are in neutral, PTO disengaged and still nothing. Any suggestion???
   / Mahindra 5570 won't turn over #2
One of your safety switches is likely tripped or possibly malfunctioning, but I'd lean towards it being tripped on a new tractor with new owner. Seat, HST treadle/pedals, brakes, clutch, pto, gear selector, are some of the places to look without knowing the specifics of your tractor. Owners manual may have more info.
   / Mahindra 5570 won't turn over #3
Quick basic suggestions:
Turn on your headlights and try to start the engine. Do headlights dim when the key is turned to the starting position?
Yes = investigate the starter and solenoid.
No = check any and all safety devices (Brake, seat, etc.)
Thanks. I will check those things out.
Thanks. I will give that a shot in the morning.
I also noticed my tractor has a "MIL" light on the dash that is lit up. This light was on the 1st time I cranked it as well. Anyone know what this may be?
   / Mahindra 5570 won't turn over #7
MIL = Malfunction Indicator Light. Just guessing, but there could be a problem that put the engine into a protected mode, making it unable to start. I would call my dealer asap and see what they say.
   / Mahindra 5570 won't turn over #8
I wouldn't worry about an MIL unless it was on while the engine was running. Most tractors I have owned will light up all the dash lights when they are first started, or when the key is on without the engine running.
   / Mahindra 5570 won't turn over #9
Was the MIL light on while the engine was running? If so, was it steady or flashing?
   / Mahindra 5570 won't turn over #10
Is the range selector by your foot in neutral? That's the one most people miss.
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2000 SCHWING P88 PORTABLE CONCRETE MIXER (A51243)
2000 SCHWING P88...
Kinze 3600 16 R Planter (A50514)
Kinze 3600 16 R...
