Mahindra 5570 won't turn over
   / Mahindra 5570 won't turn over #1
Tannyleblanc
Dequincy, LA
2015 Mahindra 5570
Recently purchased a 5570, spent about 10 minutes on it after I got it home from dealership and now tractor won't start. All lights come on as before when I turn key on but will not turn over (crank). All gears are in neutral, PTO disengaged and still nothing. Any suggestion???
   / Mahindra 5570 won't turn over #2
One of your safety switches is likely tripped or possibly malfunctioning, but I'd lean towards it being tripped on a new tractor with new owner. Seat, HST treadle/pedals, brakes, clutch, pto, gear selector, are some of the places to look without knowing the specifics of your tractor. Owners manual may have more info.
   / Mahindra 5570 won't turn over #3
Quick basic suggestions:
Turn on your headlights and try to start the engine. Do headlights dim when the key is turned to the starting position?
Yes = investigate the starter and solenoid.
No = check any and all safety devices (Brake, seat, etc.)
Thanks. I will check those things out.
Thanks. I will give that a shot in the morning.
I also noticed my tractor has a "MIL" light on the dash that is lit up. This light was on the 1st time I cranked it as well. Anyone know what this may be?
   / Mahindra 5570 won't turn over #7
MIL = Malfunction Indicator Light. Just guessing, but there could be a problem that put the engine into a protected mode, making it unable to start. I would call my dealer asap and see what they say.
   / Mahindra 5570 won't turn over #8
I wouldn't worry about an MIL unless it was on while the engine was running. Most tractors I have owned will light up all the dash lights when they are first started, or when the key is on without the engine running.
   / Mahindra 5570 won't turn over #9
Was the MIL light on while the engine was running? If so, was it steady or flashing?
   / Mahindra 5570 won't turn over #10
Is the range selector by your foot in neutral? That's the one most people miss.
2019 KENWORTH T680 (A50854)
2019 KENWORTH T680...
2017 INTERNATIONAL PRO STAR SERIES SLEEPER (A50854)
2017 INTERNATIONAL...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
2016 WINNEBAGO SCORPION 4014 5TH WHEEL CAMPER (A50854)
2016 WINNEBAGO...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51222)
2019 INTERNATIONAL...
