Mahindra 5570 Rear remote leak
   / Mahindra 5570 Rear remote leak #11
Absolutely know how to fix this. Same thing happened to mine. The seal that is used in that valve is called a quad ring. Looks like an o ring but instead of being round it’s a four sided ring that fits into a groove inside the housing and the valve shaft goes through it. The parts are not available from mahindra but they will be glad to send you a complete valve assembly for around 1100 bucks. The part you need can be found at most any hydraulic cylinder repair shop and it is a simple fix once the valve body is removed from the tractor. Supply house didn’t even charge me for the new ring as it would have cost him more in time than what it was worth to look up a cost. What you will notice is the ring that comes out of the valve from the factory is very stiff and from what I was told was not the correct material for what it was used for. Changed mine with a softer more pliable material in the same size and have never had another leak. I realize I’m several days late seeing this but hope it helps anyway. Please don’t fall for the line from the dealer about having to replace the entire valve body, it is a simple fix that at most may cost $1.00 and a little time.
I too have a leak in a Mahindra 5575 in the rear remote. How hard a job is it to take the part off and put in a new o ring? Mine has two or three hydraulic lines attached.
I too have a leak in my Mahindra 5555 rear remote. I'm not a great mechanic, but I would like to try and fix the leak myself. Can you please walk me through taking the part off and replacing the o ring once I have the remote off? Thank you in advance for your reply.
   / Mahindra 5570 Rear remote leak #12
Ignore the first reply, hit the wrong thing. I have a 5555.
UNUSED AGT MXMRW14 STAND ON WHEELED SKID STEER (A51243)
UNUSED AGT MXMRW14...
12' UTILITY SERVICE TRUCK BODY (A51244)
12' UTILITY...
2011 PETERBILT 367 T/A DAYCAB ROAD TRACTOR (A51243)
2011 PETERBILT 367...
2014 TAKEUCHI TS70R WHEELED SKID STEER (A51242)
2014 TAKEUCHI...
2020 Lincoln Naultilus (A50324)
2020 Lincoln...
Zimmerman 6 Lug Running Gear (A50774)
Zimmerman 6 Lug...
