Mahindra 5530 not starting
   / Mahindra 5530 not starting
U don’t want to get cheap injectors off the web..
Take them ALL to a diesel fuel injection shop.. or u can send them to me..
If they’re stuck, the only way that happens is if water or a heavy dose of bio fuel was in the tank..
Loosen ALL THE LINES and see if THE PUMP IS PUMPING.
I have done that. Since we thought the pump was messed up. Seems to be pumping good fuel to the injectors. If the injector is stuck open would that keep it from starting?
It did have red diesel in it. But it looked almost clear. Couldn’t see any trash.
   / Mahindra 5530 not starting #13
An open injector WILL keep the engine from starting..
It’ll force compression back up thru the line..(air)
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
SOLDERING IRONS, GLOVES, AND STANDS (A50854)
SOLDERING IRONS...
2020 CATERPILLAR 289D3 SKID STEER (A51242)
2020 CATERPILLAR...
1986 ASPT 30ft S/A Pole Trailer (A49346)
1986 ASPT 30ft S/A...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
