Mahindra 5530- need help with battery replacement
   / Mahindra 5530- need help with battery replacement #1
Cpt0617
Need to replace my battery. Can anyone tell me if theres an easy way to remove it, or does the air cleaner have to be removed? Thanks
   / Mahindra 5530- need help with battery replacement #2
I have a 5500 4x4 and i have to remove my air cleaner and all the panels, its not that bad of a job, just takes a little time. Havent change my battery yet, had to clean the post and add a new end. So far my battery is 4 years old and still working good. 3 years is a normal life. Just been lucky so far.
   / Mahindra 5530- need help with battery replacement #3
I just replaced the battery in my '08 5525. On mine, you have to remove the sheet metal in front of the battery, then the battery slides out toward the front. The metal is held on by 4 bolts (2 on each side).
2017 Peterbilt 567 Day Cab (A52384)
2017 Peterbilt 567...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
Unused 2025 CFG Industry MX12RX Mini Excavator (A50322)
Unused 2025 CFG...
