Mahindra 5530- need help with battery replacement
   / Mahindra 5530- need help with battery replacement #1
Cpt0617
Need to replace my battery. Can anyone tell me if theres an easy way to remove it, or does the air cleaner have to be removed? Thanks
   / Mahindra 5530- need help with battery replacement #2
I have a 5500 4x4 and i have to remove my air cleaner and all the panels, its not that bad of a job, just takes a little time. Havent change my battery yet, had to clean the post and add a new end. So far my battery is 4 years old and still working good. 3 years is a normal life. Just been lucky so far.
   / Mahindra 5530- need help with battery replacement #3
I just replaced the battery in my '08 5525. On mine, you have to remove the sheet metal in front of the battery, then the battery slides out toward the front. The metal is held on by 4 bolts (2 on each side).
Heritage / Woods RD 72 3 pt Finish Mower (A50515)
Heritage / Woods...
2014 E.D. ETNYRE & CO CENTER DROP HOT OIL TANKER TRAILER (A47384)
2014 E.D. ETNYRE &...
2019 John Deere 5090E (A50120)
2019 John Deere...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
