Mahindra 5525 Radiator Drain
/ Mahindra 5525 Radiator Drain #1
scsims
Central, KY
Mahindra 5525
I'm planning on draining my coolant tomorrow. The manual says there's a drain plug on the left of the crank case and one at the bottom of the radiator.
The plug on the left side is easy to find and get to, but I can't find the other one. Can anyone point me in the right direction to find it?
/ Mahindra 5525 Radiator Drain #2
When you look at the engine from left side... you can find it at right middle portion... It may be a screw also...
Do let know when you find it.. Or if you are not clear..
/ Mahindra 5525 Radiator Drain #3
Help! I can find the radiator drain on my 5525, but I can’t find the one on the LH side of the crankcase.
