Mahindra 5010 won稚 start. Battery good
   / Mahindra 5010 won稚 start. Battery good #1
regulator
carrolllton
none yet
I was bush hogging a very small area for about 5 minutes. At one point I heard a loud bang but the sound wasn稚 from hitting anything. It more sounded like someone hit the cab somewhere with a baseball bat.
I shut the tractor down for about 15 minutes and then when I tried to start it back up it clicked once and from then on nothing. Now it痴 almost as if there is no battery at all with no response. I checked the fairly new battery and it痴 fully charged.
Could the loud bang have been something electrical?
Mahindra 5010 HST cab
   / Mahindra 5010 won稚 start. Battery good #2
If you have an ECU, it could have perhaps popped. Can you turn the crankshaft with a wrench? If not, perhaps a rod let go.
I値l need to read on where the ECU is. As far as a rod everything sounded fine for the remainder of the time I was bush hogging. No odd engine noises.
I took a jump box down to the tractor to verify it was not the battery and it behaved very similar to the initial failure.
When the key was turned the lights and air conditioner came on for a split second then totally gone.
I rechecked the clamps and tried a few more times but nothing at all, no lights, no electrical response of any kind.
I was going to start looking for fuses but an instant downpour started.
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
2014 CHEVROLET IMPALA 4DOOR SEDAN (A54313)
2014 CHEVROLET...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A55302)
2022 New Holland...
Texas Post Driver Series 500 Heavy-duty Hydraulic Post Driver (A53473)
Texas Post Driver...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
