Mahindra 5010 vs. LS U5030
   / Mahindra 5010 vs. LS U5030 #1
PatMcD
Maine
LS U5030
I looked at a couple of tractors today.
One was a Mahindra 5010 (geared) with loader for $24,900 (cash or financing). This one had a Tier 3 motor, which I think is a good thing? I liked the tractor a lot. When I get closer to a decision, I'll go back and drive it around (it was in the showroom).
Other one I looked at was a LS U5030 with loader for $27,500 (also T3 engine). I also really liked that tractor. What it offered over the Mahindra was: 5 more HP, self-leveling bucket, 1 more hydro remote, adjustable lift arms, shuttle-shift. Not sure if they are worth $2600 to me, though.
How do the prices sound?
Any thoughts on the better deal?
   / Mahindra 5010 vs. LS U5030 #2
The u5030 is a slightly larger class of tractor than the Mahindra 5010. You would have to compare the Mahindra 6010 instead.
By the way, the Mahindra 5010/6010 is actually a TYM tractor (T503/603), rebadged. May be cheaper to just buy it from TYM...
   / Mahindra 5010 vs. LS U5030 #3
Buy it from TYM, get a few things that Mahindra does not offer like the extendible ends, a 16x16 shuttle tranny, 2 std rear remotes, a Cat-Perkins engine and pay less $$$. TYM makes some nice machines, just a shame that they don't have a better dealer net work, if that is important to you. I would give the TYM tractors a very serious look if I were looking for a new machine. ;)
   / Mahindra 5010 vs. LS U5030 #4
I picked up a U5030 last year and paid a couple thousand more than what you were quoted. I looked at the 5010 and felt it was a lot less machine than the 5030, but that aside, I did not like the clutch on the 5010 or 6010. It felt like it was in or out and was difficult to slip. I looked very closely at the 5035 but the operator platform was cramped (I'm 6'3), other than that I really liked that tractor but the extra remote, gears and overall comfort of the 5030 won out. The price for the U5030 and 5035 were very close.
The only downside to the 5030 is, when driving over very rough ground it's hard to keep steady pressure on the foot throttle and the RPM's tend to jump up and down as the tractor bounces. Using the hand throttle alleviates this but in some situations I want the control the foot throttle offers.
So far I have 110 hours on the 5030 with out any issues.
   / Mahindra 5010 vs. LS U5030 #5
I have a 4510 and have not been overjoyed with the 10 series at all.
   / Mahindra 5010 vs. LS U5030 #6
I tried the ls and the tym 503 this spring liked both tractors without hst . what swayed me was the tym creeper low (LL) its super slow . same dealer had both models and he leaned toward tym. both were tier 3- I bought the tym and have enjoyed it so far 33 hours worth. IMO either one is a fine tractor for the money, my local dealer had either one for just under the 27 mark. both with cab and fel
   / Mahindra 5010 vs. LS U5030 #7
yanmars, can you elaborate? I've been drooling over a 6010 HST w/ cab. I've seen some posts of people who say they like it, but also other posts of people who've reported problems (hydraulic), and there seem to be some that say to avoid the 10 series all together -- things I haven't heard about other Mahindra products. I like the weight & other specs of the 6010, and I figure if I buy one tractor I might as well get one with a cab to make it more pleasant for snow removal. I'd like the option of running a small baler which is why I figured the next smaller HST Mahindra with a cab might (3616) might be a bit underpowered, although for everything else I'd use it for, it would probably work out just fine.
   / Mahindra 5010 vs. LS U5030 #8
Sorry I do not view this daily. The 10 series is a TYM tractor as I understand. Mine and others have had the radiator clog if you mow where you get chaft and seeds. The battery and windshield washer reservoir block a great deal of air flow. I had to relocate them and add an additional fan to keep the temps under control and air blow the radiator out after every use.
If you mow over small trees the filter and lines underneath are at risk of getting damaged as is the fuel filter. I and the prior owner had to replace the same when a tree caught it and broke the pressed fittings.
Also the glass is subject to breakage, I and the prior owner broke a side glass with a limb hit. The glass was only $139 but the shipping was $309.
If I had to do it all over I would not get the 10 series. If I used it only on clean ag ground there would be no problem.
   / Mahindra 5010 vs. LS U5030 #9
I looked at LS and Mahindra when shopping for a tractor this past year.
I looked at the Mahindra 6010, 6110, 5530, 6530, 5535, and 7060 several times throughout 2014. They all had ups and downs towards what I wanted and was expecting. Then the same dealer picked up LS in mid 2014. I checked out the LS U5030C and the XU5065CPS. I really liked the overall fit, finish, and features that LS offered over the Mahindras. Then it happened... I drove by the dealer one day and a P7010C was on the lot. Love at first sight! I had to test drive it.
I ended up getting seat time on the Mahindra 6010, 6110, and 7060. Then I tested the LS XU5065CPS and the P7010C. I was really in the market for a 50-60 hp cab tractor. The 72 hp LS followed me home! No regrets!
With all this said. This is what sold me on the LS P7010C vs Mahindra 7060.
Powertrain...
72 hp (63 PTO)vs 67 hp (57 PTO).
26.4 gallon fuel capacity, with a locking fuel cap vs 19.3 gallons.
20/20 transmission vs 12/12.
540/750/1000 PTO with ground shiftable PTO (haven't found a use for that one yet) vs 540 PTO
Better radiator/oil cooler/air conditioner condenser screens (very important in hot dusty environments).
Hydraulics...
3 rear remotes vs 2 remotes.
Self leveling loader standard.
Steering pump 7.0 gpm vs 5.1 gpm (easier steering)
Main pump 12 gpm vs 11 gpm (loader and remote cycle time)
Lift capacity 6173 lbs vs 5100 lbs
Cab...
Front and rear wiper/washer standard.
12 lights vs 6 lights.
Radio standard.
Better HVAC system. Hands down colder air in LS.
Instrument cluster tilts with the steering in the LS.
Quieter cab.
And all this for less than the Mahindra. Maybe its because LS is being aggressive in pricing to gain market share. I think Mahindra was more aggressive when they came to the US and now are closer to the other color tractors. Not saying the Mahindra is a poor choice. Actually it was my first choice before I found the LS. The LS is just more refined and offers much more in feature set.
I got carried away on the specs. I was not out to bash the Mahindra, but just showing an example of how LS is becoming a very lucrative player in the US tractor market. This is just one of the apples to apples comparisons I made when I was shopping. I compared several color tractor specs against each other. Usually the LS beat the Red, Orange, and Green on paper for a given class tractor.
CT
   / Mahindra 5010 vs. LS U5030 #10
I also had it narrowed down to the Mahindra 5035 and the LS 5030. I went with the 5035 Mahindra. It out classed the LS in every category except the LS had 2 remotes and a few more HP. Mahindra loader lifted more and lifted considerably higher, something like a foot and a half. the tires were larger and wider, tractor weighed more, and was more stable. The seat was nicer on the Mahindra, it had adjustable back and arms. I did like the self leveling loader on the LS, but I needed one that would lift higher than the 24 HP small tractor I sold, and the LS did not lift much over head high! The thing that really swung it for me was the LS dealer did not act like they cared if they sold a tractor or not, and the Mahindra dealer was spot on with their treatment of me as a customer! Hope you enfoy your tractor, I have had a ball with mine!
   / Mahindra 5010 vs. LS U5030 #11
Are you sure you're comparing the same numbers?
---------------------------------Mahindra------LS-----
LOADER Model------------------ML130-----LL5102---
Lift Height-----------------------111.5"------115.5"--
Max lift weight @ full height----2700-------2900----
Breakout @ pins-----------------5100-------4790----
Tractor Weight-------------------4939-------4600----
I'm not sure what numbers you were looking at, maybe you were looking at the R4041/47 tractors instead. That loader only lifted to 96.1" and the tractor weighed right around 3900.
   / Mahindra 5010 vs. LS U5030 #12
You may be right. I looked at so many when I was shopping. I started out looking at the R4047 and then they got the 5055 model in and I looked hard at it and probably would have bought it if the dealer acted like they wanted my business! I found my brochure, and you are right. After I got to thinking about it, the one they had on the lot had a special loader someone had ordered and they backed out and did not take it. That may be where the confusion came in. I went back and forth and it came down to the dealer. The LS dealer has been in business for probably 50 years, but they were the old Allis Chalmers dealer, then agro, then Massey, then MaCormmick, and some other tractor and then the LS. I was afraid they would drop them and the next nearest LS dealer is about 3 hours away. I have a couple of other Mahindra dealers within about 1 hour. Also, in my thinking Mahindra has been around in US longer and LS has just came into our area. I already have my Dads Belarus he bought 20 years ago, and we know how that turned out. Has been a great tractor, but no support now! I would have bought a Deere, but dealers were like the LS, didnt care if they sold one and I could not get one that was tier 3 engine. Again, hope you enjoy your tractor. They look like alot of tractor for the money! Sorry for the confusion, I guess my memory does not serve me as well as I thought. I looked at the smaller ones for weeks and I knew they had the lowest lift height on the market. Was not thinking about the 5055 having that special loader. They wanted it for chicken houses or something?
I don't think you were looking at the specs for the LS U5030.
The LS has higher lift height by 4", higher lift capacity by 200lbs, etc., etc.
I don't think one can go wrong with either unit, by the way.
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A61307)
LMC 2-Row Planter...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2013 Ford C-Max Energi Hybrid PHEV Hatchback (A59231)
2013 Ford C-Max...
2010 Dodge Ram 4x4 Crew Cab Pickup Truck (A59230)
2010 Dodge Ram 4x4...
2014 Ford Flex SUV (A59231)
2014 Ford Flex SUV...
