Mahindra 5010 hydrostatic not moving
/ Mahindra 5010 hydrostatic not moving #1
Ljohnson1001
Brewton, alabama
I have a 5010 Mahindra hydrostatic transmission that will crank up fine but it will not idle up or mover in either forward or reverse. Tractor was moving just fine and then it stopped. I can let it sit for a while and it will start moving again the "F" on the dash for forward is flashing about every 5 seconds. Any idea of what could be wrong?
/ Mahindra 5010 hydrostatic not moving #2
Did you Check the hydraulic fluid level? If that’s fine move the range selector the low , medium and high sometimes that gets bumped and is not fully in range
The levels are all full. I went thru each range 3 times still would not move. After I started looking at pedals and switches I believe I found the problem. My brakes were way loose. I adjusted the brakes and it brought the pedals up to the correct hieght. I believe they were just sitting a little low and not making the proximity switch. Brakes adjusted and have been using the tractor for about the past 1 or so and no issues so far.
/ Mahindra 5010 hydrostatic not moving #4
Have you washed it recently?
