Mahindra 5010 HST
   / Mahindra 5010 HST #1
Rumgudgeon
Mahindra 5010
Hello,
My 5010 hydro just started acting up. The tractor will not run forward or reverse after a few minutes of operation. I have noticed that it will start to slow down in its travel speed and then when I stop the direction of travel, the foot pedals will not move the tractor forward or reverse. The loader and 3pt hitch will still work as expected. If I let the tractor sit for 4-5 minutes it will start moving again, only to slow down and then ultimately stop moving in forward/reverse. I am slightly over on my scheduled maintenance at 600 hours and the hydraulic oil filters need to be changed at 550. I called the dealership and they are suspecting a bad hydro. Does anyone have any information on what I can look for as indications of a bad hydro and is there a chance that an oil/filter change will improve the HST function?
   / Mahindra 5010 HST #2
did u check the levels?
   / Mahindra 5010 HST #3
In 2019 my 2815 stopped moving also , no forward or reverse and first thought was HST failure. Another symptom was steering. It turned out I had just lose a hydraulic pump. Word to the wise if it does turnout to be a pump then you might want to consider replacing both as you probably loose the other later. I lost the other pump a year later.
Service manual will show how to hookup a pressure gage to check the HST.
Chery Q.A 66" Rock Bucket (A50121)
Chery Q.A 66" Rock...
Yale Electric Pallet Jack (A50514)
Yale Electric...
2016 JLG 2646ES 26ft Scissor Lift (A50322)
2016 JLG 2646ES...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
Parker 400 bu Gravity Wagon (A50515)
Parker 400 bu...
(10) 20' Continuous Fencing Panels (A50515)
(10) 20'...
