Mahindra 5010 HST
   / Mahindra 5010 HST #1
Rumgudgeon
Mahindra 5010
Hello,
My 5010 hydro just started acting up. The tractor will not run forward or reverse after a few minutes of operation. I have noticed that it will start to slow down in its travel speed and then when I stop the direction of travel, the foot pedals will not move the tractor forward or reverse. The loader and 3pt hitch will still work as expected. If I let the tractor sit for 4-5 minutes it will start moving again, only to slow down and then ultimately stop moving in forward/reverse. I am slightly over on my scheduled maintenance at 600 hours and the hydraulic oil filters need to be changed at 550. I called the dealership and they are suspecting a bad hydro. Does anyone have any information on what I can look for as indications of a bad hydro and is there a chance that an oil/filter change will improve the HST function?
   / Mahindra 5010 HST #2
did u check the levels?
   / Mahindra 5010 HST #3
In 2019 my 2815 stopped moving also , no forward or reverse and first thought was HST failure. Another symptom was steering. It turned out I had just lose a hydraulic pump. Word to the wise if it does turnout to be a pump then you might want to consider replacing both as you probably loose the other later. I lost the other pump a year later.
Service manual will show how to hookup a pressure gage to check the HST.
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50775)
PLEASE CHECK...
Kubota 48in Bucket (A50322)
Kubota 48in Bucket...
Kubota B7200 (A50120)
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
2014 Ford F-450 Altec AT200A 30ft Bucket Truck (A50323)
2014 Ford F-450...
