Loader Mahindra 5010 Gear Loader (ML151/156) valve assyembly (joystick) repair question
   / Mahindra 5010 Gear Loader (ML151/156) valve assyembly (joystick) repair question #1
JohnNewalla
Newalla, Oklahoma
Mahindra 5010 Gear
Cross referencing Part No. 86253005002 "VALVE ASSY, JOYSTICK" with Mahindra's parts, I found this part to be $1,370. Price shock. Price shock.
My question, is there a repair kit on the market?
Taking the boot off the joystick, I can see the assembly and where a large nut has broken in two. (under the joystick, appears to be two rods (for lack of a better word) on the top right and bottom right, on the bottom left, the moving part(s) seems to be held to the frame by a nut welded to the frame. This nut broke in half and the joystick provides no control for the bucket (yes I have a limp joystick...not good). Further more, depending on the location of the rods I mentioned above, the bucket will rise up on it's own (never down???).
Is there a way to repair this damage nut (a repair kit on the market) or do I need to break open my kids piggy bank to buy the whole assembly. The whole assembly by the way includes where the hydraulic hoses connect, plus Joy Stick assembly.
I appreciate any relevant advice. Nearest dealer is 40 miles....
   / Mahindra 5010 Gear Loader (ML151/156) valve assyembly (joystick) repair question #2
Do you think you could do some creative welding or maybe find a good welder who could?
   / Mahindra 5010 Gear Loader (ML151/156) valve assyembly (joystick) repair question #3
Who makes that loader, the ML151/ML156? You might do better going to OEM. I'm sure they use that valve on other loaders.
JB Weld sure didn't do the trick LOL, i'm new to this are so I will have to research for a good welder. Thank you
Mahindra makes this loader, or at least they market they do
   / Mahindra 5010 Gear Loader (ML151/156) valve assyembly (joystick) repair question #6
Joystick valves can be had for much less than the $1300 range - shop around, check Surplus Center etc. I'd be willing to bet that you could find one more in the $300-400 +/- range, that is if you can't have yours repaired easily.
UNUSED KIVEL HANG ON WHEEL LOADER PALLET FORKS (A51244)
UNUSED KIVEL HANG...
2012 Ram 1500 Crew Cab Pickup Truck (A50323)
2012 Ram 1500 Crew...
TRUCKING INFO (A50775)
Year: 2007 Make: Ford Model: Taurus Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A51694)
Year: 2007 Make...
Howse 10' 3pt Rotary Mower (A50774)
Howse 10' 3pt...
2013 MACK GRANITE (A52472)
2013 MACK GRANITE...
