Loader Mahindra 5010 Gear Loader (ML151/156) valve assyembly (joystick) repair question
   / Mahindra 5010 Gear Loader (ML151/156) valve assyembly (joystick) repair question #1
JohnNewalla
Newalla, Oklahoma
Mahindra 5010 Gear
Cross referencing Part No. 86253005002 "VALVE ASSY, JOYSTICK" with Mahindra's parts, I found this part to be $1,370. Price shock. Price shock.
My question, is there a repair kit on the market?
Taking the boot off the joystick, I can see the assembly and where a large nut has broken in two. (under the joystick, appears to be two rods (for lack of a better word) on the top right and bottom right, on the bottom left, the moving part(s) seems to be held to the frame by a nut welded to the frame. This nut broke in half and the joystick provides no control for the bucket (yes I have a limp joystick...not good). Further more, depending on the location of the rods I mentioned above, the bucket will rise up on it's own (never down???).
Is there a way to repair this damage nut (a repair kit on the market) or do I need to break open my kids piggy bank to buy the whole assembly. The whole assembly by the way includes where the hydraulic hoses connect, plus Joy Stick assembly.
I appreciate any relevant advice. Nearest dealer is 40 miles....
   / Mahindra 5010 Gear Loader (ML151/156) valve assyembly (joystick) repair question #2
Do you think you could do some creative welding or maybe find a good welder who could?
   / Mahindra 5010 Gear Loader (ML151/156) valve assyembly (joystick) repair question #3
Who makes that loader, the ML151/ML156? You might do better going to OEM. I'm sure they use that valve on other loaders.
JB Weld sure didn't do the trick LOL, i'm new to this are so I will have to research for a good welder. Thank you
Mahindra makes this loader, or at least they market they do
   / Mahindra 5010 Gear Loader (ML151/156) valve assyembly (joystick) repair question #6
Joystick valves can be had for much less than the $1300 range - shop around, check Surplus Center etc. I'd be willing to bet that you could find one more in the $300-400 +/- range, that is if you can't have yours repaired easily.
2004 Volvo XC90 VAN (A55853)
2004 Volvo XC90...
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
WHISPERWATT 220 DIESEL POWERED GENERATOR (A55745)
WHISPERWATT 220...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
2006 Peterbilt 335 Day Cab Truck (A53117)
2006 Peterbilt 335...
2021 Ford F-600 4x4 Mechanics Service Truck (A55852)
2021 Ford F-600...
