Mahindra 5010 fuel pump.
   / Mahindra 5010 fuel pump. #1
Tjmcginnis
Mahindra 5010
Mahendra 5010 gear cab
I no longer here my electric fuel pump ticking when I turn my ignition on. I’m assuming it needs to be replaced.
Does anyone have any tips on replacing this part.
Had the fuel lift pump go out on a commens And burned out the injection pump. No fun to replace.
Would not want that to happen to my tractor.
Thanks for any help .
   / Mahindra 5010 fuel pump. #2
First off, check for voltage at the pump. Should be ~12V with the key on. If no voltage, check the fuse and make sure you are getting 12 volts at the fuse and through it.
Charlotte County (A50323)
Charlotte County...
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A52377)
2012 Chevrolet...
UNVERFERTH 330 8 AND 1/2 INCH EXTENSION STUB TUBE WELDMENT FOR FRAME (A55301)
UNVERFERTH 330 8...
2018 UTILITY VS2RA 53FT REEFER TRAILER (A54607)
2018 UTILITY VS2RA...
