Mahindra 5010 fuel pump.
   / Mahindra 5010 fuel pump. #1
Tjmcginnis
Mahindra 5010
Mahendra 5010 gear cab
I no longer here my electric fuel pump ticking when I turn my ignition on. I’m assuming it needs to be replaced.
Does anyone have any tips on replacing this part.
Had the fuel lift pump go out on a commens And burned out the injection pump. No fun to replace.
Would not want that to happen to my tractor.
Thanks for any help .
   / Mahindra 5010 fuel pump. #2
First off, check for voltage at the pump. Should be ~12V with the key on. If no voltage, check the fuse and make sure you are getting 12 volts at the fuse and through it.
STORAGE FEES (A54313)
2010 John Deere TX Gator 4x4 Utility Cart (A52377)
2010 John Deere TX...
2013 Cadillac SRX SUV (A53424)
2013 Cadillac SRX...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
