Mahindra 4530 won't start
   / Mahindra 4530 won't start
remember the voltage readings can fool you without a load..
12volts (unloaded) aint nothing if the voltage drops 50% with load.. Glad you got it fixed, my battery cables need constant attention
That was one of the things that helped me figure it all out. I have a battery tester that has the ability to place a load on the battery. With no load I had 12.91 volts with a load it only dropped to 11.83 but it would drop to 10.7 at the solenoid without a load. I cut the insulation off the cable after I replaced it and it had all kinds of battery acid corrosion.
   / Mahindra 4530 won't start #12
good tester, you would be surprised how many folks think 12v on the meter means full power available
UNUSED IRGC80 Battery Powered Golf cart (A55272)
UNUSED IRGC80...
2018 Kubota RTV-X900 4x4 Diesel Utility Cart (A59228)
2018 Kubota...
TANK MANIFOLD (A55745)
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
NIPPON HYD THUMB (A52706)
NIPPON HYD THUMB...
Motorcycle (A59231)
Motorcycle (A59231)
