Mahindra 4510 loss of oil
   / Mahindra 4510 loss of oil #1
yanmars
My Mahindra 4510 started to get warm, not hot. I brought it back to the barn. Raised the hood and saw fluid all over the engine compartment. Radiator was down about 1.5 quarts on a 8 quart system. Oil was down about 2 quarts on a 8 quart system. The oil pan bolts etc. were not loose. The oil filter was not loose. The radiator cap was not loose. Any thoughts where an external oil leak could occur? Unsure if it has an external oil cooler or connection.
   / Mahindra 4510 loss of oil #2
   / Mahindra 4510 loss of oil #3
Was it antifreeze or oil? You are down both but which was sprayed all over . Of course pics help
   / Mahindra 4510 loss of oil #4
Clean everything really well. Fill your oil. Fill your water. Leave the hood raised and look for the leaks. It sounds like it's seeping pretty fast. If you're in your garage you may wish to put a drip pan under the tractor.
2015 CATERPILLAR 272D2 WHEELED SKID STEER (A50458)
2015 CATERPILLAR...
2019 CATERPILLAR 308 CR EXCAVATOR (A51242)
2019 CATERPILLAR...
Pallet Of Mini Excavator Attachments (A47384)
Pallet Of Mini...
2019 FREIGHTLINER SPRINTER 2500 (A51219)
2019 FREIGHTLINER...
2018 Generac MLT6SM-STD3 6kW Towable Light Tower (A49461)
2018 Generac...
2005 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2005 Big Tex 10PI...
