Mahindra 4510 loss of oil
   / Mahindra 4510 loss of oil #1
yanmars
Veteran Member
My Mahindra 4510 started to get warm, not hot. I brought it back to the barn. Raised the hood and saw fluid all over the engine compartment. Radiator was down about 1.5 quarts on a 8 quart system. Oil was down about 2 quarts on a 8 quart system. The oil pan bolts etc. were not loose. The oil filter was not loose. The radiator cap was not loose. Any thoughts where an external oil leak could occur? Unsure if it has an external oil cooler or connection.
   / Mahindra 4510 loss of oil #2
   / Mahindra 4510 loss of oil #3
Was it antifreeze or oil? You are down both but which was sprayed all over . Of course pics help
   / Mahindra 4510 loss of oil #4
Clean everything really well. Fill your oil. Fill your water. Leave the hood raised and look for the leaks. It sounds like it's seeping pretty fast. If you're in your garage you may wish to put a drip pan under the tractor.
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2013 F-550 Bucket Truck (A51039)
2013 F-550 Bucket...
2017 John Deere 855D 4x4 Gator Utility Cart (A50322)
2017 John Deere...
2013 Ford Econoline E350 Passenger Van (A49461)
2013 Ford...
2020 New Holland 105 Workmaster MFWD Compact Tractor with 632TL Front Loader - Poultry Special (A51039)
2020 New Holland...
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
