Mahindra 4110 Glow Plugs/Relay/Controller?
   / Mahindra 4110 Glow Plugs/Relay/Controller? #11
I have just recently changed the fuel filter on my Mahindra. I bled the filter housing as well as injectors. when i start it up, it shoots up to max rpm's and i have to turn it off. any ideas?
   / Mahindra 4110 Glow Plugs/Relay/Controller? #12
First things first - move your throttle lever/foot pedal and watch at the injector pump to see that it is operating the lever back and forth. Usually the hand throttle and the foot pedal will each have their own cable and come together somewhere close to the injector pump, something could be binding there somehow.
   / Mahindra 4110 Glow Plugs/Relay/Controller? #13
Skip,
appreciate the info, looked at both throttle cables and they appear fine and not getting stuck.
   / Mahindra 4110 Glow Plugs/Relay/Controller? #14
OK, make sure that the throttle lever that the cables operate on the pump is actually moving back & forth and turning the shaft it is mounted on, going into the injection pump. If that looks good, I would guess a problem internally with the governor. Can't give you any direct advice on that other than let a good shop look at it.
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
2023 MECALAC AS600 WHEEL LOADER (A51242)
2023 MECALAC AS600...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
UNUSED JCT SKID STEER QUICK ATTACH AUGER SET (A51244)
UNUSED JCT SKID...
2013 Digger Derrick (A50323)
2013 Digger...
