Mahindra 4025 won't start
   / Mahindra 4025 won't start #1
Muladzh
TN
Kioti CK20, Mechron 2200, Mahindra 4025. Grasshopper 735 BT
I am having a problem with my 2wd 4025 - it will not start - the range interlock appears not to be functioning as the key does nothing when turned - battery full charged, fuel good, oil level good and clean oil.
When starting the 4025 it is necessary to place the range selector in neutral, then turning the key kicks in the starter, tractor starts and we go play in a field. Yesterday the starting routine failed to start the tractor. Irrespective of what position the range selector lever was in, the key turned with no accompanying roar of diesel power. I need to know where the start interlock is, and if I can get at it. The range selector comes out of the left side of the transmission housing, with no obvious switches or wires apparent.
There are 34 hours in one year on the tractor.
now fixed
Lights work, no dimming, battery fully charged.
Solved: there are two interlock switches - I knew of one, but not the other. The PTO lever has one that had come loose and did not engage when the lever was forward. Tightened it up on the screw and it worked. I am very happy about this.
   / Mahindra 4025 won't start #6
Welcome to TBN.
Have you checked the fuses?
   / Mahindra 4025 won't start #7
The original post was over a year ago. He resolved the problem in post 4 by fixing the PTO switch.
   / Mahindra 4025 won't start #8
Being his first post, I figured cutting some slack on proper forum etiquette was due... Being the case of no lights and nothing on the switch, I figured the issue was quite different than the OP's interlocks.
   / Mahindra 4025 won't start #9
6/12/2016 I'm having the same problem with my Mahindra 4025 4WD. I checked all the fuses on the dash and they are good but I have no lights or horn. I charged the battery and it is good. The manual says something about some kind of pump start fuse. I have no idea what that is or where to find it's fuse. I have not checked the PTO switch yet but I will when it stops raining.
As it is pouring rain and the radar shows it will be awhile before it clears up, I'll use this time to go back and re-read the etiquette note. I'm so mad over this year old tractor that I probably didn't retain what I read. Thanks in advance for any ideas.
JC Cooper
   / Mahindra 4025 won't start #10
I am having same problem on a 2009 4025 2wd - It will not start - without moving the range interlock lever back and front a few times.
Battery is strong - Changed the range selector switch - Same problem ---
Looking for some help?
50 CAT 5 TOOTH EXCAVATOR BUCKET (A50854)
50 CAT 5 TOOTH...
2012 FREIGHTLINER CASCADIA (A50854)
2012 FREIGHTLINER...
2018 Toro Groundsmaster 7200 72in Zero Turn Mower (A48082)
2018 Toro...
1273 (A50490)
1273 (A50490)
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
