Mahindra 4025 4x4 - leaking mystery hose
   / Mahindra 4025 4x4 - leaking mystery hose #1
Mandres
Houston, TX
Kubota
Hi fellas, can anyone help me identify this hose on my father-in-laws 4025? It runs from under the seat down through the floorboard and connects underneath the machine. The hose is leaking hydraulic oil (I think) and appears to have been chafed by the metal strap that secures it near the seat rail. You can see the shiny worn section of the braided hose where the leak is.
Also is there a way to tilt the seat up on this model to access underneath? If not I'll need to pull the whole seat off.
Thanks for the help! I was finally able to get the pic uploaded. Does that match the line you linked?
-edit after searching a little bit this guy had an issue with the same hose. His pics are much clearer. Mahindra 4025 Hydraulics
   / Mahindra 4025 4x4 - leaking mystery hose #4
yes, I had to replace mine
Also, there was a left hand and right hand version of the line, the way the tube was bent at the banjo fitting. Can't remember which was the correct one.
Thanks again for the help. I received the part today and will be installing tomorrow.
I appreciate Simon's advice on tilting the seat too. I was scratching my head over that one.
New/Unused Agrotk Tire Changer (A51573)
New/Unused Agrotk...
2025 New/Unused LandHonor Leaf Blower (A51573)
2025 New/Unused...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
2018 John Deere 310L 4x4 Extendahoe Loader Backhoe (A52377)
2018 John Deere...
2007 Freightliner M2 106 Ambulance (A51692)
2007 Freightliner...
