Backhoe Mahindra 3710 by KMW
   / Mahindra 3710 by KMW #1
AchingBack
Southern Oregon
Mahindra 2615HST
The access panel for the lever mechanism is practically impossible to reinstall. The one on mine is actually to big and so tight, it takes two people to wrestle it into position for lining up and inserting the bolts. Am I the only one with this problem? It's so bad I shudder at the thought of removing it to do maintenance or repair.
Other than the above problem, the 3710 performs great.
   / Mahindra 3710 by KMW #2
why are you taking the dash column apart?
   / Mahindra 3710 by KMW #3
3710 is made by TYM the loader is made by KMW
Perhaps my post wasn't clear. Nevertheless, the 3710 is not made by TYM, and I am not taking the dash column on my tractor apart. The backhoe linkages need occasional lubrication, and or parts replacement. Those linkages are accessed through a bolted on panel on the hoe.
   / Mahindra 3710 by KMW #5
ahhhh we are talking about a backhoe that's my bad
drill the holes bigger on the side it needs more room
   / Mahindra 3710 by KMW #6
When did Mahindra stop using the Bradco backhoes? BobG in VA
   / Mahindra 3710 by KMW #7
They have always had a few different suppliers for backhoes depending on model its going on
Thanks for the tip. The holes are oval slots. I'm going to enlarge them with a chainsaw file.
UNUSED CFG Industrial MX12RX Mini Excavator (A47384)
UNUSED CFG...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
2006 Ford F-150 Pickup Truck (A48081)
2006 Ford F-150...
3001 (A51691)
3001 (A51691)
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
Rhino 484 84in Rotary Cutter (A50322)
Rhino 484 84in...
