Mahindra 3535 sheer pin
   / Mahindra 3535 sheer pin #1
OklahomaHillbilly
Inola, Oklahoma
Mahindra 3535, Honda 4518
Hello all!
I have been lurking here for awhile trying to educate myself on tractors and options. I have wanted to upgrade from my old Ford 2000 gas tractor. My field is nothing but grass and I was plumb fed up with having more brush hog than tractor. (old Ford 2000 and 5 foot heavy duty brush hog with 1/2" blades) That poor old Ford struggled so bad and didn't have low enough gearing to take it slow. I also needed a FEL. I have eyed the Mahindras for awhile. Finally I bought one.
So first, thanks for all of the insight. It was really nice to read and learn here. I feel like I was able to make a much more educated choice.
So now, the request for help. :D
I bought a 2010 Mahindra 3535 with the fel. I bought a new 5 foot standard duty brush hog without the clutch. (oops...) I finally got the tractor delivered and with a big old grin i jumped on it to give it a try. She fired up like a dream. I pushed the pto button and bang! The sheer pin in the brush hog bit it in 1/10th of a second. I wasn't all the way idled down but it wasn't revved either. I drove into town the next morning and got a grade 8 bolt to put back in. It worked (i used very low idle to start it) but it sounds really scary when it fires up. Talk about a hard starting son of a gun... I learned here about the accumulator fix for the hard starting pto.
The question is how do I know if mine already has the upgrade? The dealer thought it did. I am concerned about running other implements and damaging them. I will get the slip clutch added to my brush hog but that doesn't help any other implements.
It has the auto pto mode but I wouldn't dream of trusting it with a tiller or anything. I get the feeling it will break stuff. :mad:
Thoughts or advice?
   / Mahindra 3535 sheer pin #2
8 grade bolt as a shear pin is a no no, you need a weak link. :(
   / Mahindra 3535 sheer pin #3
I agree with Jim, that grade 8 bolt for a shear bolt isn't a idea. Look under your right foot rest and see if there is a little metal tank under there. If there is then the tractor is up to date.
Hmm... Well sounds like I am headed back to the hardware store for some grade 2 bolts. Thanks for the advice on that.
I don't see the accumulator there. Am I looking in the right spot?
   / Mahindra 3535 sheer pin #5
Brother, that grade #8 bolt for a shear pin is harder that most of the other pto componets, thoughs #2 or #3 shear pins are cheaper that an internal parts. I thinks I would be talking to the dealer or dealer reps.
Good luck with whatever you do, but you have a nice tractor. enjoy
david
   / Mahindra 3535 sheer pin #7
Use grade 5 bolts, grade 2 are to weak grade 8 are to strong. I have used grade 5 for several years with no problems.
   / Mahindra 3535 sheer pin #8
the way your are describing it is doing the same thing mine did before I had it fixed with the accumulater issues. no issues since it was fixed but prior to that it started so hard. I think it was even shearing of grade 5 in a second.
donawilcox,
Can you post a picture of the accumulator? I am pretty sure mine doesn't have it but I would like to be armed with information before I call the dealer back up to fix it. He didn't seem sure of what I was talking about when I mentioned this to him.
John Deere 848G Grapple Skidder (A52384)
John Deere 848G...
UNUSED CFG INDUSTRIAL QK16R EXCAVATOR (A51247)
UNUSED CFG...
2008 FREIGHTLINER M2 106 (A53843)
2008 FREIGHTLINER...
24" SINGLE MANUAL RADIUS STEP (A51248)
24" SINGLE MANUAL...
(2) ROW PLANTER W/ COLE PLANTERS (A51247)
(2) ROW PLANTER W/...
378467 (A51572)
378467 (A51572)
