Mahindra 3510 running hot
   / Mahindra 3510 running hot #11
The 3510 radiator fins are too small. Real easy to clog up and if battery sits high, it will restrict air flow.
I lowered the battery with a kit from Mahindra and use Radiator Genie to keep fins cleaned out. Last year, I gave it a good cleaning out with HVAC Condenser Cleaner spray and good washing with Radiator Genie.
Too much water or air pressure can bend the fins causing overheating.
Be gentle washing it out.
   / Mahindra 3510 running hot #12
The radiator on the 3510 is very dense. I just removed mine today and was surprised at how much junk was in it AFTER cleaning while in the tractor. I used 3 upside down buckets to lay it on and sprayed with some mixed Dawn and water, then cleaned, flipped over, repeat. Flipped a few more times and lots of water spray. Finished with air hose.
NOW I ca see through it with a flashlight. If you can't, it ain't clean yet.
1992 Ingersoll Rand 185 185CFM Towable Air Compressor (A55973)
1992 Ingersoll...
2022 Western Star W47005B Dump Truck, VIN: 5KKHAXDV6NPNJ0431, Detroit Turbo Diesel Engine, Tandem (A59076)
2022 Western Star...
2016 Case 580N EP Backhoe, S/N JJGN58EPLGC729072, Diesel Engine, 4 x 4, 80" Front GP Bucket, 22" (A59076)
2016 Case 580N EP...
2017 Ford F-350 Flatbed Service Truck (A56858)
2017 Ford F-350...
Honda utv cart (A56859)
Honda utv cart...
JCB Forks and Frame Skid Steer Attachment (A56857)
JCB Forks and...
