Mahindra 3510 PTO not working. NEED HELP
   / Mahindra 3510 PTO not working. NEED HELP #1
GregLM
Jasper, Fl
Mahindra 3510 4wd gear
Tried to engage the pto but it does nothing. the lever is up in the 540 position and the selector switch in the manual position ant the switch is pushed in and light up.
   / Mahindra 3510 PTO not working. NEED HELP #2
One day while mowing, the PTO suddenly stopped working on my 2555! The button was engaged and the light was on. Thought I'd broken something internally. Upon further investigation, discovered that a stick or something had caught and disconnected the wire to the PTO solenoid under the tractor, plugged back in and all was fine. You may want to check that out on yours.
   / Mahindra 3510 PTO not working. NEED HELP #3
It's been years since I have messed with one of these, but if I recall correctly there is an engagement solenoid that gets sticky/rusty if the PTO is not used for a while. If you are setting in the seat, look at where your right heel is. Then climb under the tractor and look about at that point and find the solenoid and take it apart. That'll get it working again.
2019 KENWORTH T880 (A50854)
2019 KENWORTH T880...
1993 Ford Ranger STX Ext. Cab Pickup Truck (A50323)
1993 Ford Ranger...
2019 JCB 457 ZX T4F Articulated Wheel Loader (A49461)
2019 JCB 457 ZX...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A51039)
2019 Ford F550 4x4...
2015 JLG G12-55A 12,000lb 4x4 Rough Terrain Telehandler (A49461)
2015 JLG G12-55A...
2013 PETERBILT 367 DAY CAB (INOPERABLE) (A50854)
2013 PETERBILT 367...
