Oil & Fuel Mahindra 3510 leaking at front steering joint
   / Mahindra 3510 leaking at front steering joint #11
I'm not sure, it's obviously different from mine so what I said may be out the window for yours.... If it is the same design yes, you can knock the old one out fairly easily with a heavy bladed screwdriver or chisel, taking care not to scratch the wall of the hole that the cup seals against. Then I use a large socket that fits the cup well and knock it back in with a compothane hammer so as not to damage my socket. I don't recommend trying to install it by using a punch or similar around the edge of it, you will distort the cup and it won't seal well. Be careful not to damage the rubber coating on the cup too.
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
2215 (A58376)
2215 (A58376)
SOFTBALL & BASEBALL HITTING & CATCHING GEAR (A58374)
SOFTBALL &...
24220 (A56859)
24220 (A56859)
GRAIN AUGER (A52708)
2017 FREIGHTLINER CORONADO SD122 DAY CAB (A56138)
2017 FREIGHTLINER...
