Mahindra 3510 fluid change
   / Mahindra 3510 fluid change #1
johnnyZ
Had a broken line -repaired it added new fluid Ihave nothing, pto wont engage bushhog,front loader bucket will not move. I have little knowledge of tractor just got it used. I need help to trouble shoot this.
   / Mahindra 3510 fluid change #2
Where was your broken line? How much fluid did you lose?
   / Mahindra 3510 fluid change #3
Was it working before you lost fluid? How long did you run it after you lost fluid? How full did you refill it after repair? Im not sure where the pump is on yours, but on my 7520 it is above the surface of the normal oil level. You may have to overfill to get it to prime. :confused:
larry
Line broke under tractor Used to be hard pipe I believe at filter down from o ring connection. Ran just a short period lost good bit of fluid between shutoff and repair. Ran fine up to this point
   / Mahindra 3510 fluid change #5
Make sure you put enough fluid in the system. I ran a stick through one of those rubber hoses on the filter canister not long after I got my 4110, which is the same basic unit as the 3510 gear with bigger tires and more HP. I did a hydro fluid and filter change two days ago, took nearly ten gallons of fluid.
If you don't have enough fluid your loader won't work, and since the PTO has a hydraulic clutch it won't work. The fluid level should be checked with the 3 pt lowered, as well as the loader.
   / Mahindra 3510 fluid change #6
There is a fluid level dipstick on the top of the left rear axil housing, in case you didn't know.
   / Mahindra 3510 fluid change #7
It takes an awfully lot of Hy-Trans before you get that dipstick wet. I think people underestimate how much fluid it takes, since you are draining from a low point you will pull fluid out of the cylinders on the loader, etc.
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52128)
Kubota 24in Quick...
1996 PETERBILT 357 35 TON WRECKER (A50505)
1996 PETERBILT 357...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
AGT Agrotk 680 Drop Hammer Attachment (A47384)
AGT Agrotk 680...
Hours : 1114 (A50323)
Walking Floor Trailer 43ft (A50322)
Walking Floor...
