Mahindra 3510 4x4
   / Mahindra 3510 4x4 #1
truckerhicks73
2003 Mahindra 3510
Inherited my Dad's 3510 had it serviced. Should've asked them if it is full time 4x4 and what the shift patterns are on the two shifters. It seems to not pull with the front axle.
   / Mahindra 3510 4x4 #2
   / Mahindra 3510 4x4 #3
I have a 4510. Unsure how close they are but I once had some type of simple clip break and I did not have the front tires pulling. The shop made it a simple cheap fix. Obviously could be other issues.
   / Mahindra 3510 4x4 #4
Lever to left side of seat engages front axle (forward)
You may have to back up slightly to pull front axle lever backwards to disengage
Left hand long lever is low, med, high ranges
Right hand long lever is gears 1,2 3 & 4
   / Mahindra 3510 4x4 #5
4510 is the same, just the cab model of the 4110 with 4 more hp
The 3510 is the little brother with 34 hp, no cab option
   / Mahindra 3510 4x4 #6
You can take a piece of fine sandpaper and buff the top of the shifter knobs and see the patterns again under that plastic layer, whatever it is. A little vinyl trim restorer will keep it clear for awhile. Be extremely careful moving the 4x4 shifter in & out of gear - you WILL bend the shift fork inside the trans if not very gentle. Sometimes it takes several tries back & forth from forward to reverse to move it. The fork isn't very expensive or difficult to replace but you have to drain the hydraulic fluid (8 gal) to do it.
   / Mahindra 3510 4x4 #7
Tractor will shift smooth if it is not rolling when you shift.
Here is a manual
  • Model_3510_4110 Owners manual.pdf
   / Mahindra 3510 4x4 #8
Here you can get a service manual;:giggle:
willy
   / Mahindra 3510 4x4 #9
2014 Transcraft Trailer (A55973)
2014 Transcraft...
(2) HOMELITE BLOWERS (A58374)
(2) HOMELITE...
2014 HEIL TRAILER INTERNATIONAL CRUDE TRAILER (A58214)
2014 HEIL TRAILER...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt GPI Pump (A59076)
LOT: Fuel Transfer...
2007 Toyota Camry (A56859)
2007 Toyota Camry...
CAT 777B ARTICULATED DUMP TRUCK (A58214)
CAT 777B...
