Mahindra 3215 transmission leak?
   / Mahindra 3215 transmission leak? #1
Carr73
Evans GA/ Aiken Co SC
Mahindra 3215 4WD
I thought I felt the transmission slip today so I inspected everything after parking the tractor. It looks like there is a minor leak somewhere on the left rear axle flange. This piece or axle tube has the wheel hub side and the inner side . It is coming from somewher on the inner side at the top. I checked the oil and there was alot of pressure when I inscrewed the top.The oil is on the low mark so I definetly need to add some. Is this suposed to be a presurized system? If not is there a crankcase ventilation valve that could be clogged?
   / Mahindra 3215 transmission leak? #2
No the hydraulic , transmission, rear end case shouldn't be pressurized, and a clear plastic vent hose should come from under the seat area in the rear and be attached by the Rt fender. Check to make sure it is open. That may stop your fluid leak.
Thanks for the quick response, I will check this tomorrow.
I found the tube right where you said it was and it was clogged. It looked like a mudd dobber nest. Anyway, it was clogged with dirt about 1/2 inch. Everything is fine now.
71067 (A49346)
71067 (A49346)
2014 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2014 Ford F-450...
2023 Komatsu WA320-8 Articulated Wheel Loader (A49461)
2023 Komatsu...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
