Carr73
I thought I felt the transmission slip today so I inspected everything after parking the tractor. It looks like there is a minor leak somewhere on the left rear axle flange. This piece or axle tube has the wheel hub side and the inner side . It is coming from somewher on the inner side at the top. I checked the oil and there was alot of pressure when I inscrewed the top.The oil is on the low mark so I definetly need to add some. Is this suposed to be a presurized system? If not is there a crankcase ventilation valve that could be clogged?
