Oil & Fuel Mahindra 3016
   / Mahindra 3016 #21
White smoke out the exhaust means you are getting fuel to the injectors, and the fuel is getting vaporized by the injectors, but the fuel is not igniting. This can be due to several simple things.
The simplest of all is that the starter isn't cranking the engine fast enough to get the compression up enough to fire the mixture. Of course that is simple to fix. At most it would be battery, starter, and solenoid. You can check these things with a Volt/Ohm/Ammeter and some know-how. They are the same on diesel tractors or gasoline cars.
White smoke could also be something as simple as not getting enough air in to mix with the vaporized diesel. So it could be as simple as a plugged air filter or a mouse nest in the intake manifold. I've seen both.
It could be old fuel with low cetane rating....but you've changed that. So that's not it.
Less likely is that the injectors have gotten old and are not spraying a good pattern for starting. That's less common, and it doesn't happen overnight. It's a progressive failure. This is where things tend to get mechanical, so if you aren't a mechanic it's time to get one to come out. The diesel mechanic can pull the injectors out, crank the engine and watch the spray pattern and come up with a pretty good guess if the injectors are the problem. Doing this also checks the low pressure fuel feed pump if there is one, and gives us some information on the high pressure fuel pump feeding the injectors.
Suppose the injectors are decent. Now is when we step back and take stock.
We know that white smoke from the exhaust is also very common when trying to start a worn engine with low compression that is also cold. In fact it is so common to old worn engines that we have been trying to ignore that possibility all along. But now it's time to check those things. Don't despair, check first. We do know that pre-heating the block or intake is the classic way to get an old worn diesel engine going. And we know that although it's a pain, they can function for years that way. Difficult strarting, and kind of down on power, but usable.
However, once an engine needs to be hot to start easily it is time to check for age & that means a compression check. The mechanic can do that while checking the injectors. In fact, she probably will check compression anyway just for curiosity. If compression is low, it's time to re-new the upper end of the engine..... ugh, but the result is an engine that runs like new.
If a compression check shows that compression is good (HOORAY!!) and you can check the injectors for a decent spray pattern, then the next place to go is to look at the high pressure fuel pump to the injectors. Make sure that the pump cam is not worn or has slipped timeing. For dealing with the high pressure fuel pum you definitely need a real mechanic.
Most of the rest of the stuff I've mentioned can be done in the barn by an amateur willing to do it.
Good luck, hope it's something simple. It usually is.
rScotty
Very good advice here rScotty. . .I have the same machine. . .I am pretty sure it is something simple.
LOT: (6) Office Chairs (A59076)
LOT: (6) Office...
New/Unused Self Dumping Hopper (A57454)
New/Unused Self...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2005 Sterling Acterra Tender Truck (A56438)
2005 Sterling...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
44052 (A55852)
44052 (A55852)
