Buying Advice Mahindra 3016 vs. Mahindra eMax vs something else? Vineyards and large lawn
   / Mahindra 3016 vs. Mahindra eMax vs something else? Vineyards and large lawn #11
As others have already mentioned, I would HIGHLY, HIGHLY advise getting a dedicated ZERO TURN MOWER. Forget the mid mount mower. You place looks very upscale and if you have weddings and events, you'll want to maintain the high quality of lawn cut with a zero turn. Not only are they leaps and bounds faster and more efficient than a tractor-style mower, they also will give a cut quality that no tractor with a mid mower will be able to remotely touch. Buy yourself a good used commercial grade zero turn that hasn't been abused and you'll thank all of us next year and wonder why you ever thought you wanted a tractor for your mowing needs. My recommendations for a zero-turn mower would be Grasshopper or Hustler.
As for tractors, you need to do some research to look into the chemical spraying requirements like someone has already mentioned. If it turns out that you must have a tractor with a cab, you're likely not going to find a brand new one in your budget. Cabs add a lot of cost to a machine. But you should also be looking at other brands. Mahindras as certainly capable machines, but my personal opinion is that they cost more than they should. They lack attention to detail in terms of fit and finish and considering that they were one of the highest prices machines in my search, I couldn't justify spending more money on a machine I didn't think was worth the cost. Personally, I would recommend looking into LS and Kioti tractors as competition. Take your budget of $16-$18k and see what kind of machine that will buy in either the LS or Kioti brand and then compare that machine with what the same $16-$18k will buy you from Mahindra. Weight the pros and cons of each and go from there. LS and Kioti are both South Korean companies are coming on strong in terms of "bang for your buck".
   / Mahindra 3016 vs. Mahindra eMax vs something else? Vineyards and large lawn #12
Super nice property. You did good:thumbsup:
Those slopes are pretty sporty so think hard about tractor safety. It's not difficult to roll a tractor if it's center of gravity is too high for the slope. You should shop for a tractor with wide stance and low axle height above ground level. That MF135 tractor I showed previously in this thread is 84" wide measured to the outside of the tires and the centerline of the rear axle is about 16" above ground level. The diameter of the rear rims is 16". You can rescale these dimensions to specify a tractor that fits your vineyard row spacing and trellis selection with a high safety factor.
Good luck and be careful out there.
   / Mahindra 3016 vs. Mahindra eMax vs something else? Vineyards and large lawn #13
Many tractor dealers with work with you to configure a tractor with low center of gravity. My tractor dealer, Dave's Tractors in Red Bluff CA, has reconfigured new 30-40 hp Mahindra tractors occasionally to squat low like my MF135 for orchard work in Tehama County. Dave posts regularly here on TBN (DavesTractors).
2006 Heil Tanker Trailer Heavy Duty 65K GVWR Tank Trailer (A56435)
2006 Heil Tanker...
2022 John Deere 1023E MFWD Compact Utility Tractor with 120R Front Loader (A56435)
2022 John Deere...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
John Deere 6110M (A53317)
John Deere 6110M...
2022 Brush Wolf ALPHA-XP Skid Loader Brush Cutter (A56435)
2022 Brush Wolf...
