Mahindra 3016 vs 3616
   / Mahindra 3016 vs 3616 #31
First post to this forum, NEWBIE! I too couldn't make up my mind 28xl, 3016,3616. I have 6 acres of flat fine loam pasture. No care for 50 years.
I used a Bobcat 122 (about the physical size of xl28) to rotary cut weeds and I needed a chiroprator when I was done. I feel the 28xl is good size for my small farm but I'm afraid, if I don't go with 3016 or 3616, I will be lame before I get the land prepared. Sooo I thought 3016 would be a good compromise. but could it handle a large rototiller? I have a 9N and 2b plow, disc, lister and cultivator from dad, but the 9N doesn't run. Hence looking for new tractor. Will the 3016 basically handle larger implements in good soil?
Should I just man up and buy 28xl for 2yrs, getting the land setup and stay small and less expensive. I would think it would be good size for maintence.
Welcome to TBN.
I'd say if you want to push the envelope a little on implement size for a mower or tiller, than I'd suggest the 3616. It is 8 HP more, which is substantial when mowing tall grass or tilling. The 3616 uses a little larger tire (if you go with the R4 tires) than the 3016, and you could air them down a little and get a better ride.
2020 Caterpillar 259D3 Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
New/Unused Mini Crawler Dump (A57453)
New/Unused Mini...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
2017 Ford F-350XL (A57148)
2017 Ford F-350XL...
14179 (A55788)
14179 (A55788)
