Mahindra 3016 Throwout Bearing removal
   / Mahindra 3016 Throwout Bearing removal #1
Eddie L
Ford 3930
Working on a friends tractor. It sat for a while and got water in the bell housing The clutch stuck to the flywheel , I assume it got hot, the throw out bearing is stuck and the fingers on the pressure plate were destroyed. Every single finger broke and scattered around the bell housing
The tractor is apart. The clutch was fairly easy to get removed but I can't get the throw out bearing out. Is there a trick to this ? The dealer said to remove the snap ring at the rear of the bell housing and it should slide apart. It not working and worried I will damage the transmission if I put a puller on it. Thanks for any advice .
   / Mahindra 3016 Throwout Bearing removal #2
I don't know that clutch setup, but if the TO bearing is on a manual clutch rod, remove the linkage to get more movement to remove from the fingers.
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2020 INTERNATIONAL MV607 24FT NON CDL BOX TRUCK (A52576)
2020 INTERNATIONAL...
2010 CHEVROLET SILVERADO 3500 (A52472)
2010 CHEVROLET...
2018 Gatormade 20+5 Gooseneck Trailer (A53472)
2018 Gatormade...
VOLVO ECR88 EXCAVATOR (A52472)
VOLVO ECR88...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
