Hi,
I'm considering buying a 3016 that is slightly used (80 hrs).
It comes with a 72" MMM and FEL with quick detach 72" bucket.
Does anyone know if the MMM is a drive over deck for install/removal? I'm new to anything beyond a lawn tractor. Any advice on servicing the blades, ie what's the easiest way to lift the deck to remove the blades?
My lawn is a bit bumpy but I tend to cut it at about 3". Is there going to be a huge difference between a 60 and 72" MMM regarding scalping, etc? I do like that it extends out past the tires for trimming around things.
It has the aux hydraulics set up to run a FEL already but no FEL. Would I be best to buy a Mahindra brand FEL or an aftermarket unit. Kind of bummed the Mahindra doesn't offer a power thumb. Not sure I need it but the option would be nice.
I'm also looking at the max 26 XL new, Kubota B2650 vs 3350 w/cab (slightly used) vs JD 2025 vs 2032. Have tons of other questions but I'll start with the above. A JD 2320 with MMM and FEL also recently showed up on CL for a decent price. Currently have 10 acres, 3-4 are grass, the rest woods. a fair amt of slopes, one hill. I had concerns about the 3016 for lawn mowing duties but I test drove it this weekend on some fairly soggy ground and it probably left less marks than my lawn tractor would have (3016 has turf tires) so I'm a little less worried now.
Thanks,
Tom
Thanks,
Tom
