Mahindra 3015
   / Mahindra 3015 #1
dennisoates
tawas mich
f-12
Hello,
I just purchased the 3 cylinder diesel Mitsubishi and finally found the dipstick. Now I can't find the hole to put it in. Is it way behind the oil filter? There is a front end loader on it and I don't have the best view.
How do I fine this hole? Does the filter have to come off?
Poor design if you ask me.
   / Mahindra 3015 #2
Did you not find the dipstick by removing it from the hole (dipstick tube)? Search the general vicinity with a good flashlight. I had to remove the hood side panels to access mine, if yours is similar I would get them out of the way.
   / Mahindra 3015 #3
You apparently found and removed the dipstick without removing the oil filter. Reverse the process. If you remove the filter (which won't be in the way, anyhow) you'll also drain a substantial amount of oil negating any check you may have performed with the dipstick. If you think about it the loader is not part of the tractor, it's an accessory. I'm sure the dipstick was readily accessible before the loader was added. Now you need to figure the easiest way to access the dipstick with the loader in place.
2013 PETERBILT 367 DAY CAB (INOPERABLE) (A50854)
2013 PETERBILT 367...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2025 Gold Mountain 12ft X 20ft Single-Truss Steel Carport (A48081)
2025 Gold Mountain...
Fuel Tank (A50860)
Fuel Tank (A50860)
Unused 2025 40ft. Texas Pride FT835524KGN 13 Ton T/A Gooseneck Flatbed Trailer (A49346)
Unused 2025 40ft...
2022 FORD F-150 XL EXT CAB TRUCK (A51406)
2022 FORD F-150 XL...
