Mahindra 2816 pto speed fluctuating
   / Mahindra 2816 pto speed fluctuating
There is nothing externally attached to the overrun clutch.
The PTO lever will only slide a collar in/out of mesh with the other gears to engage/disengage the PTO.
I was trying hard to find a manual for that tractor, so I could see how the overrun clutch is setup.
Yes. Thanks. I would like to see something but the model was made only two years or so and it seems difficult to find anything. I did see a YouTube video with a guy adjusting that sleeve you mentioned that slides back and fourth to engage/disengage the pto. Watching that it can be see how it is possible that could be out of adjustment etc. I am not sure but would not moving the linkages affect how much that sleeve travels to engage the overrunning clutch.? When I saw the slow down in pto speed then I became more concerned. The only thing I got to put on the pto for load at the moment is a snowblower. I was going to get a post hole digger for an important job but now I am holding off until I can find out what this issue is. The pto was used very little on this tractor but I was suspecting within a year I would need it a lot.
   / Mahindra 2816 pto speed fluctuating #12
Try it first when you have a chance and then let us know how it goes.
Unfortunately, my participation on this forum will be very limited from now on. Turns out that due to new compliance regulations for visitors from the European Union, I'm no longer able to login in this forum, unless I'm using a VPN like I'm doing now.
I'll still poke every once in a while to see if you solved the issue.
I have a video of the sound. Just can’t seem to upload it
   / Mahindra 2816 pto speed fluctuating #14
Not sure if you can post the video directly on the forum. You may have to upload to Youtube and then post the link here. On Youtube, you can set the video as public, non listed or private. In private, no one but you can watch the video. The other two works good.
   / Mahindra 2816 pto speed fluctuating #15
Not to derail this thread but what is this all about? Never heard of such a thing!
Yes. Tried logging in to an old YouTube account. Managed to remember all the passwords but could see no where to allow me to upload. So I went to the video on my phone and tried uploading to YouTube from there. But it痴 saying google account has been temporarily disabled. I壇 like for someone to hear it. Hopefully later today or early tomorrow morning I値l get a chance to look at the tractor
   / Mahindra 2816 pto speed fluctuating #17
European Union come up with some data and privacy protection law in 2018. Every since they implemented that, I could access Kubota USA website, HomeDepot, TractorSupply, and a lot more other websites. Mainly, because those websites didn't comply with whatever standards European Union wants to.
This wasn't a big deal to me, except, earlier this week, I had to re-login on TBN and I couldn't. I reached over to Muhammad on the Welding forum and this is what he told me:
"The issue is related to new compliance regulations for visitors from the European Union that are going into effect on September 30, but we implemented compliance yesterday. Unfortunately complying with the regulations are causing our websites to break for European visitors.
We will look into a resolution but it's possible that these regulations will make it impossible for Europeans to post for quite some time. I wish I had a better answer but this is the reality of the situation right now."
Turns out, it's now affecting TBN too, at least temporarily. Along with me, several other people had emailed him with the same issue.
I did found a work around to it, that was using a VPN to login and stayed login. After that, I can access TBN without VPN as long as I'm logged in. Otherwise I can't login and I have to use a VPN to login again.
Sorry for the off topic Vroom. I would like to ear too but Youtube is making it hard.
   / Mahindra 2816 pto speed fluctuating #18
Yes sorry for the off topic Vroom. Curiosity got the best of me.
I hope you can get the video posted as well.
I just tried again but it says google temporarily disabled this app or account. I can send it by an email . Hoping I can get out tomorrow just for quick look at the linkage for the pto handle /clutch engagement.
Very few hours running attachments on this pto. Dealers mechanic highly doubtful it could be the pto internal over running clutch. I really only ran a snowblower off of it for one winter And it was a small area and I clutched the attachment in slow each time. If lack of use could be a culprit I壇 suspect that a lot more than use or abuse.
2014 Liebherr L538 Articulated Wheel Loader (A56857)
2014 Liebherr L538...
2018 INTERNATIONAL LT625 (A58214)
2018 INTERNATIONAL...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND64FDGH1772 (A57453)
2015 Freightliner...
2013 Sakai SV510 Pad Roller, Chassis# VSV21-1033, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2013 Sakai SV510...
2014 Nissan Sentra Sedan (A56859)
2014 Nissan Sentra...
TANK MANIFOLD (A58214)
