Mahindra 2816 hst ploughing vs Ford 8n
   / Mahindra 2816 hst ploughing vs Ford 8n #1
VroomVroom
Platinum Member
Newfoundland
Mahindra 2816 HST, Super M farmall, J5 bombardier, 230 timber jack skidder
I’m curious of the comparison if anyone has experience with these. I only see videos on the older Fords pulling 2 bottom plows etc. What would be the similarities or differences to a mahindra 2816 or 3016. Mine is hst, industrial tires, no added weight except fel. 4x4. To a standard 8n while ploughing?
Yeah. Was wondering if the mahindra could plow as well as the Ford
   / Mahindra 2816 hst ploughing vs Ford 8n #4
I have a mahindra 2810 4x4 shuttle , i used to pull a 2 bottom plow with it a long time ago and it did fine, I quit plowing after i got a tiller, much better than plowing and disking.
Ok. What size plow did you use. Was it with industrial tires on it? Fel? I would imagine hst would work well for it. Yes, here if the ground hasn’t been turned in a long time they may plow first then till then after
Also, how big of a garden you plow?
   / Mahindra 2816 hst ploughing vs Ford 8n #7
The 600-900 series ford tractors are nearly double the HP of the N series but usualy not much more money. I would get one of them over a N series.
   / Mahindra 2816 hst ploughing vs Ford 8n #8
It would depend in part on what soil you have, and the size of the plow. Most of the older Ferguson plows had 12 or 14" bottoms; when going into a 16, I believe they only recommended a single bottom for the "N"s.
The big thing is the tire size; while the Ns were about the same weight and higher geared, they also stood taller.
I have a single bottom Ford 101 which is bigger than the Fergusons, but made for a full sized tractor. Even on my 3301 the point won't come up off the ground very far, so I have to be careful.
The 8n is under 30 hp similar to mine at 28 engine hp. So is imagine they’d perform similar. I have 4x4. I’m surprised to see the weight very similar. Figured the old Ford would have been heavier
   / Mahindra 2816 hst ploughing vs Ford 8n #10
The bigger tire size is the difference I see. I was turning new ground with my old 275, next to my strawberries and running up the rows each time. What I didn't notice was that the plow point was dragging, as it only came about 4 inches off the ground; and my strawberries were growing on hills.
I took out every one of those plants. :eek:
100 FUEL TANK (A53843)
(2) COLUMN PROTECTORS (A51248)
(2) COLUMN...
(1) FRIGIDAIRE REFRIGERATOR (A51248)
(1) FRIGIDAIRE...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
JOHN DEERE HX14 LOT NUMBER 226 (A53084)
JOHN DEERE HX14...
2016 Freightliner M2 106 Medium Duty 26FT Box Truck (A51692)
2016 Freightliner...
