Mahindra 2816 Help
   / Mahindra 2816 Help #1
talon636
Atlanta, GA
Mahindra 2816
I have a Mahindra 2816 that the pto won't lift. The bucket does, but the bush hog won't come up. I have checked to make sure the valve is opened all the way and top off the fluid. Any other ideas?
   / Mahindra 2816 Help #2
Hydraulics:
Type: open center
Valves: 0 or 1
Pump flow: 7.8 gpm [29.5 lpm]
Steering flow: 3.5 gpm [13.2 lpm]
If FEL works, you have flow through all the valves to tank.
You are talking about the 3pt will not lift a bush hog.
Is the bush hog to heavy?
If you installed a hyd gage in a tee in the IN port of the FEL valve, you could monitor and trouble shoot the hyd system.
If the gage were installed and you raised the lever, you would see the pressure required to raise the bush hog.
If your 3pt valve is good, then the seals on the 3pt cyl is bad and bypassing the fluid.
Do you have hyd input going into the 3pt?
Some people using a BH, will bypass the 3 pt system.
2017 John Deere 650K LGP Crawler Dozer (A50860)
2017 John Deere...
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A51039)
Kubota BX2680...
48in Forks Loader Attachment (A49346)
48in Forks Loader...
2017 Ford F550 4x4 Bucket Truck - 45FT Terex TL40 Boom, Powerstroke Diesel, Utility Bed, 54K Miles (A51039)
2017 Ford F550 4x4...
JOHN DEERE 5205 TRACTOR (A51406)
JOHN DEERE 5205...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
