Mahindra 2815 hst differential lock
   / Mahindra 2815 hst differential lock #1
ThomasKibbee
Mahindra 2815 hst
Hi, my diff lock does not lock, the cog gear that engages the differential is apparently worn. Does anybody know the step by step method of replacing this?
   / Mahindra 2815 hst differential lock #2
I would first make sure there is nothing apparently wrong with the pedal/linkage. Don't know if you have tried engaging it while the tractor is moving and get the "click,click, click" like it's not engaging...which it isn't...or if possibly you are getting this all the time when you stop the tractor, engage the pedal then take off again? Point being...always stop the tractor before engaging the diff lock.
If the lock is worn, the differential will have to be disassembled to repair it. In the diagram, part #13 is the lock sleeve and most likely what is worn if this is indeed the issue. The first thing I would recommend is getting a service manual to help with this and any future issues. You can look at parts diagrams here http://www.mahindrapartsplus.com/pages/OemParts?aribrand=MHD and looking at the rear end...it sure looks like it was made by Mitsubishi....or it's a very good copy of their design. I know the 15/16 series tractors had Mitsubishi engines but after seeing the parts diagram, I wonder if they made some of the drivetrain components too? The 2815's differential looks pretty much identicle to a Mitsubishi MT300's....I really can't find a single difference between the 2815's diagram and my Mitsubishi manual.
2018 Ram 3500 Bucket Truck with Duralift DTS29 - 34FT Walk-In Bucket, HEMI Gas, 98K Miles (A51039)
2018 Ram 3500...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2015 Ford F-250 4x4 Ext. Cab Pickup Truck (A50323)
2015 Ford F-250...
2010 Gleaner 9250 Draper Head  30' with Crary Air Wind System (A51039)
2010 Gleaner 9250...
Lincoln Electric Vantage 300 Welder/Generator (A49461)
Lincoln Electric...
1998 CATERPILLAR IT28G WHEEL LOADER (A51242)
1998 CATERPILLAR...
