Mahindra 2810 Crack in Knuckle Arm?
   / Mahindra 2810 Crack in Knuckle Arm? #1
Mahendra420
Valdosta,Ga
Mahindra 2810
Own a 2810 Mahin 150318_0005.jpg150318_0005.jpgdra noticed when greasing the knuckle steering arm grease shooting out a hair line crack on both the left and right knuckle arms on each side of the tractor is that crack supposed to be there or is it damage thanks? Have a photo both from a distance and close up.
   / Mahindra 2810 Crack in Knuckle Arm? #2
I'm not an expert on Mahindra tractors but don't believe you have to be because the grease is not suppose to come out of a crack, it should be going down to steering joint .
DevilDog
You see the arc that's where the grease is oozing out and its on thee left side as well currently. It steer fine no problems but noticed it when greasing both sides today.
Here's a view of the right side with greasing out see the arc again?150318_0008.jpg
If it is a crack? How long will it hold up and how much to repair $$$$ thanks?
   / Mahindra 2810 Crack in Knuckle Arm? #6
Oh man, that can't be good! I would suggest you go ahead and replace them asap, before one of them fails completely and causes more damage to other components. I would show these pics to a Mahindra rep and see what they have to say about it. I bet it's something they've already seen before, and if so, getting them to admit it might be hard to do.
Korean "POT" metal from Mr Haney Factory?
   / Mahindra 2810 Crack in Knuckle Arm? #8
Is that where two castings or forgings are pressed together? The "cracks" look very regular to be a break, esp on both sides. Definitely check with the dealer svc dept. it's wrong in any case. How old is the machine?
Jim
2002 manufacture hope with no fracture.I'm getting drunk think I bought a lemon.
I know I should've bought that Case 420 skidsteer ****** boy!
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2018 FREIGHTLINER...
1,000 Gallon Horizontal Fuel Storage Tank with Pump - Farm or Construction Ready (A51039)
1,000 Gallon...
2012 Chevrolet Traverse SUV (A50324)
2012 Chevrolet...
Marliss Industries Grain and Soybean Drill - Selling ABSOLUTE NO RESERVE (A51039)
Marliss Industries...
2015 Dodge 5500 4X4 Bucket Truck (A51039)
2015 Dodge 5500...
2024 New Holland T8.410 MFWD Tractor (A51039)
2024 New Holland...
